PowerPro 205Si
SKU# PP-205SI
- Unit Weight: 65 lb
- Shipping Weight: 86 lb
- Unit Dimensions: 9.75 in × 25 in × 15 in
The PowerPro 205Si combines AC/DC TIG welding, DC Stick welding, and plasma cutting in one compact, versatile unit. It’s an excellent choice for small fabrication shops, maintenance crews, and hands-on builders who need the flexibility to weld and cut without transporting multiple machines.
From shop fabrication and factory maintenance to general field repairs, the PowerPro 205Si delivers capability wherever portability matters. TIG welding provides precise control for steel, stainless steel, and aluminum, while DC Stick welding offers a practical option for general repairs and jobsite work. The unit can weld material up to 1/4" thick and handle thicker sections with multiple passes.
The integrated plasma cutter adds even more versatility, allowing you to hand-cut steel, stainless steel, and aluminum up to 5/8" thick with a suitable compressed-air supply. Whether you’re building, repairing, or maintaining equipment, the PowerPro 205Si brings three essential processes together in one convenient package.
- AC/DC TIG for welding Steel, Stainless and Aluminum metal types
- Dual-Voltage Input allows the unit to go anywhere a weld or cut is needed
- Adjustable Pulse up to 250Hz on TIG if desired for improved bead appearance
- AC Frequency and Balance Controls for improved TIG control
- Stick function works well with iron powder and titania fluxed rods
- Plasma cutter designed for hand cutting can cut up to 5/8" with ease
- 9500 Surge Watts
- Not for use with E6010 and most cellulosic rods
- E6011 use is permissible but performance may be brand dependent
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 32 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 25 A
| LCD Screen | No
| Memory | No
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 200 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 18.0 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 200 Amps
HF Start with Point Gap Start
| Start Amp Range AC | 20-200A
| Start Amp Range DC | 5-200A
| End Amp Range AC | 20-200A
| End Amp Range DC | 5-200A
| TIG Pulse | AC
| AC Pulse Type | Standard
| AC Frequency | 20-250 Hz
| AC Balance | 10-90% of Positive Electrode
| AC Wave Forms | Square
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 160A/26.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 130A/25.2V Rated Output
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 5 to 160 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.2 to 26.4 Volts
| Hot Start | Fixed
| Hot Start Time | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | No
Use 6011 for best results
| TIG Function | Built In Gas Valve Standard Torch
| Plasma Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 50A/100V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 40A/96V Rated Output
| Plasma Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 50 Amps
240V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 100 Volts
| Open Circuit Voltage (OCV) | 280V
| Torch Type | iPT60
| CNC Capable/Ready | No
| Gouging Capable | No
| Gouging Duties | No Gouging Permitted, Voids warranty
| Recommended Flow Rate (Air) | 5.7 CFM
| Compressor Built In | No
| Recommended Cutting Pressure Range | 65-75 PSI
| Remote | 2T
| Tip Saver Function | No
| Location of CNC Port | No CNC Port
| Torch Connector Type | Threaded with 35 DINSE Power Adapter
.007" to 5/16"
.007" to 5/16"
.025"- 1/4"
1/16"- 5/32"
- Up to 1/2" daily use
- Up to 5/8" clean cut
- Up to 3/4" severance cut
- Pierce up to 1/2"
- NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
- IPT-60 Hand Plasma Torch Blow Back Start 14 Ft. Threaded Connector
- 2T/4T Torch Switch for TIG welders 7 pin female 15 Ft.
- Consumable Starter Kit for TIG (No Tungsten)
- 55-60A Consumable Starter Kit for Plasma
- 6.5 Ft. Power Input Cable with NEMA 6-50 Plug
