PowerTIG 210EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 1
PowerTIG 210EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 2
PowerTIG 210EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 3
PowerTIG 210EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 4
PowerTIG 210EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 5
PowerTIG 210EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 6
PowerCool 375 Front
PowerCool 375 Front
SKU# PT 210EXT-375LF-WC375-BUNDLE-210
Digital AC/DC
$2,557.00
$2,069.00
Save - $488.00
Digital AC/DC
The PowerTIG 210EXT bundle package includes the PowerCart 375LF and the PowerCool 375 water cooler. This package gives you everything that normally comes with the PowerTIG 210EXT including the standard accessory package. The cooler included in this package stacks securely under the PowerTIG 210EXT with a smooth, connected look. The cart is designed to hold both the welder and cooler If the cooler isn't needed, it can hold just the welder as well. Adjustable tabs on the cart keep the welder and cooler from sliding around. This package is perfect for small shops and fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
  1. PowerTIG 210EXT
  2. PowerTIG 210EXT Accessories
  3. PowerCart 375LF Welding Cart
  4. PowerCool W375 Water Cooler
  2. 7,500 Surge Watts
  1. Not for use with E6010 stick welding rods
  2. TIG lift start requires a remote to start arc. It is not a live lift function.
Package Notes:
  1. Each item in this package may vary in warranty length. The warranty listed for this package is only for the welder itself.
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 26.8 A
240V 1 Phase 50/60Hz: 23.5 A
120V 1 Phase 50/60Hz: 21 A
240V 1 Phase 50/60Hz: 19 A
9 Programs
On-Arc
Cooler Control
Runs Continuously
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/15V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 210A/18.4V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 170A/16.8V Rated Output
120V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 3 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 15 Volts
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 5 to 210 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.2 to 18.4 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 3 to 210 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.1 to 18.4 Volts
80V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
5-(125)210A
Start Amp Range DC
3-(125)210A
End Amp Range AC
5-(125)210A
End Amp Range DC
3-(125)210A
0-25 Seconds
0-25 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
5-100% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
5-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
.007" to 5/16"
.007" to 5/16"
.025"- 1/4"
1/16"- 5/32"
  • Aerospace
  • Rail Car Industry
