PowerTIG 325EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 1
PowerTIG 325EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 2
PowerTIG 325EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 3
PowerTIG 325EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 4
PowerTIG 325EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 5
PowerTIG 325EXT & W375 Cooler & Cart 375LF & Nova Kit (Bundle), view 6
PowerCool 375 Front
PowerCool 375 Front
SKU# PT-325EXT-375LF-WC375-BUNDLE-325
Digital AC/DC
$3,557.00
$2,700.00
Save - $857.00
Digital AC/DC
The PowerTIG 325EXT (240V 1 and 3 phase model) bundle package includes the PowerCart 375LF and the PowerCool 375 water cooler. This package gives you everything that normally comes with the PowerTIG 325EXT (240V 1 and 3 phase model) including the standard accessory package. The cooler included in this package stacks securely under the PowerTIG 325EXT with a smooth, connected look. The cart is designed to hold both the welder and cooler If the cooler isn't needed, it can hold just the welder as well. Adjustable tabs on the cart keep the welder and cooler from sliding around. This package is perfect for small shops and fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
  1. PowerTIG 325EXT (240V 1 and 3 phase model)
  2. PowerTIG 325EXT Accessory Package
  3. PowerCart 375LF Welding Cart
  4. PowerCool 375 Water Cooler
  2. 15,500 Surge Watts
  1. TIG lift start requires a remote to start arc. It is not a live lift function.
Package Notes:
  1. Each item in this package may vary in warranty length. The warranty listed for this package is only for the welder itself.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 60 A
240V 3 Phase 50/60Hz: 30 A
240V 1 Phase 50/60Hz: 36 A
240V 3 Phase 50/60Hz: 18 A
21S
9 Programs
On-Arc
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 320A/22.8V Rated Output
240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 320A/22.8V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/18V Rated Output
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 10 to 320 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 22.8 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 320 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.8 Volts
240V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 320 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 22.8 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 320 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.8 Volts
88V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
10-320A
Start Amp Range DC
5-320A
End Amp Range AC
10-320A
End Amp Range DC
5-320A
0-25 Seconds
0-50 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
5-100% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
5-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Sine
.007" to 1/2"
.007" to 1/2"
.008"- 3/8"
1/16"- 5/32" (3/16" some rods)
  • Aerospace
  • Rail Car Industry
