PowerTIG 400EXT (3Ph 480V) & W401 Cooler & Cart 301 & Nova Kit (Bundle), view 1
PowerTIG 400EXT (3Ph 480V) & W401 Cooler & Cart 301 & Nova Kit (Bundle), view 2
PowerTIG 400EXT (3Ph 480V) & W401 Cooler & Cart 301 & Nova Kit (Bundle), view 3
PowerTIG 400EXT (3Ph 480V) & W401 Cooler & Cart 301 & Nova Kit (Bundle), view 4
PowerTIG 400EXT (3Ph 480V) & W401 Cooler & Cart 301 & Nova Kit (Bundle), view 5
SKU# PT 400EXT-480V-301-W401-BUNDLE-9
Digital AC/DC
$4,827.00
$4,100.00
Save - $727.00
Digital AC/DC
  • Unit Weight: 105 lb
  • Unit Dimensions: 11.5 in × 25 in × 24 in
The PowerTIG 400EXT (3Ph 480V) bundle package includes PowerCool W401, PowerCart 301, and Nova Kit. This package gives you everything that normally comes with the PowerTIG 400EXT (3Ph 480V) including the standard accessory package. The cooler included in this package stacks securely under the PowerTIG 400EXT with a smooth, connected look. The cart is designed to hold both the welder and cooler. If the cooler isn't needed, it can hold just the welder as well. The thumb screws that connect to the bottom of the cooler from under the cart and the top capture bar on the cart keep the welder and cooler from sliding around. This package is perfect for small shops and fabrication facilities that need a compact water-cooled package. Be sure to add a cover after selecting this package under the "add accessories" option to keep the welder protected when not in use.
Includes:
  1. PowerTIG 400EXT (3Ph 480V)
  2. PowerTIG 400EXT Accessories
  3. PowerCool W401 Water Cooler
  4. PowerCart 301 Welding Cart
  2. 15,500 Surge Watts on 1 phase 240V
  1. E6010 mode operates best with a short arc
  2. TIG lift start requires a remote to start arc. It is not a live lift function.
240V 3 Phase 50/60Hz
240V 1 Phase 50/60Hz: 79 A
240V 3 Phase 50/60Hz: 39 A
240V 1 Phase 50/60Hz: 48 A
240V 3 Phase 50/60Hz: 24 A
21S
9 Programs
On-Arc
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 3 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 400A/26V Rated Output
240V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
240V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/20V Rated Output
240V 1 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 26 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
240V 3 Phase 50/60Hz TIG Amp AC Output Range: 10 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt AC Output Range: 10.4 to 22.8 Volts
240V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
240V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
70V
TIG Start Type
Lift Start With Remote
Start Amp Range AC
10-400A
Start Amp Range DC
5-400A
End Amp Range AC
10-400A
End Amp Range DC
5-400A
0-25 Seconds
0-50 Seconds
0-25 Seconds
0-25 Seconds
TIG Pulse
AC
AC Pulse Type
Advanced
DC TIG Pulse Wave Shape
Square
DC Pulse Frequency
0-500 Hz
AC Pulse Frequency
0-250 Hz
AC Advanced Pulse Frequency
0-9.9 Hz
5-95%
Pulse Amperage
5-100% of Welding Amperage
AC Frequency
20-250 Hz
AC Balance
5-90% of Positive Electrode
AC Wave Forms
Square
Soft Square
Triangular
Sine
.015" to 1/2"+
.015" to 1/2"+
.025"- 1/2"+
1/16"- 1/4"
  • Aerospace
  • Rail Car Industry
  • Pipe and Structural
Downloads
