Tempest 401i with Wire Feeder and Cart Package, view 1
Tempest 401i with Wire Feeder and Cart Package, view 2
Tempest 401i with Wire Feeder and Cart Package, view 3
Tempest 401i with Wire Feeder and Cart Package, view 4
Tempest 401i with Wire Feeder and Cart Package, view 5
SKU# TMP-401-480-Package
MIG
$4,199.00
$3,799.00
Save - $400.00
MIG
Built for industrial professionals, the Tempest 401i MIG package brings rugged construction and versatile welding performance to shipyards, fabrication operations and demanding field work. IP23-rated ingress protection, potted circuit boards and durable internal construction help protect the power source in tough working environments. Its compact size makes it practical to move between jobs or integrate into skid-mounted power racks.
The Tempest 401i supports MIG, DC scratch-start TIG, Stick and air carbon arc gouging, giving crews the flexibility to weld, repair and remove metal with one power source. For gouging, connect a suitable gouging torch and compressed air supply, select the gouge mode and get to work.
The heavy-duty 500A wire feeder delivers feed speeds exceeding 850 IPM (22 m/min). With the optional longer umbilical, it can operate up to 75 feet from the power source, extending your reach across large workpieces and jobsites. An included MIG, TIG and Stick accessory package rounds out a versatile industrial welding system.
  1. Operating on 480V 3 Phase power yields up to 400A output at 60% Duty Cycle
  2. DC Power Source for MIG, DC TIG, Stick and gouging operations
  3. MIG crater fill helps maintain maximum control when terminating the arc
  4. Simple, intuitive controls for easy setup and adjustment
  5. Bright, easy-to-read LCD for reading the screen at a distance
  6. Detachable wire feeder allows wire feeder to be carried over 75 feet away without moving the powersource
  7. Optional longer Umbilicals for greater service distances with wire feeder (75 feet)
22 gauge to 1/2+"
20 gauge to 1/2+"
1/8"- 1/2+"
Common Recommended Metal Types and capabilities For DC TIG**:
.015" to 1/2"
.015" to 1/2"
Not to be welded with DC TIG.
Gouging:
up to 1/4" electrode (@ 400A on 480V)
480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 16 A
480V 3 Phase 50/60Hz: 12 A
MIG Duty Cycle 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/34V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 310A/29.5V Rated Output
MIG Output Range 480V 3 Phase 50/60Hz
480V 3 Phase 50/60Hz MIG Amp DC Output Range: 60 to 400 Amps
480V 3 Phase 50/60Hz MIG Volt DC Output Range: 17 to 40 Volts
72V
MIG Crater Fill (End Fill)
Adjustable
Adjustable
Auto ON or OFF Seconds
MIG Pulse
None
Spool Sizes
12”
.062”
4
(External Feeder)
PowerSet Simplified Pro Setup
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Wire Feed Speed
850 IPM
Torch/Gun
North 24 Series 10 Ft.
Actual MIG gun type and configuration ultimately depends upon the wire feeder type and the optional accessories purchased. Torch or Gun may vary depending upon feeder or suitcase configuration. Multiple gun options exist for each feeder type if a feeder is purchased separately
24 gauge to 1/2"
20 gauge to 1/2"
1/8"- 7/16"
*Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes. Aluminum range is limited due to the spray process required for non-pulse MIGs to make a proper weld. Short circuit can be accomplished on thinner metals, but welds may not be structurally sound. For best results with the standard MIG gun feeding with the red polymer liner and U-groove drive rolls, use .040, .047 (3/64").
.030" to 1/2+"
.030" to 1/2+"
**Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes. Input voltage affects maximum output and capability as well.
Maximum Stick Electrode Size:
1/4"
  • Rail Car Industry
  • Pipe and Structural
