Tempest 412i with Wire Feeder and Cart Package
SKU# TMP-412-240-480-PC301-V-205
- Unit Dimensions: 11.25 in × 26.5 in × 15 in
Built to meet the demanding standards of professionals who need dependable multi-process power day-in and day-out, the Everlast Tempest 412i brings serious output and versatility to fabrication shops, structural welding, and heavy repair work. This multi-process DC power source combines MIG, TIG, Stick and gouging capability in one platform, with the performance to take on demanding jobs and the flexibility to fit your operation.
Choose from compatible standard MIG, pulse MIG or suitcase wire feeders to build the system around your work. The power source itself supports DC TIG with Lift Start or Scratch Start, along with dedicated standard and cellulosic Stick modes for a broad range of common electrodes. A dedicated gouging mode adds the ability to remove damaged welds and prepare joints for repair, making the Tempest 412i a practical foundation for a complete welding and gouging setup.
With 400A output at a 60% duty cycle on 480V three-phase power, the Tempest 412i delivers the muscle and sustained performance professionals expect from a competitive industrial welding system. On 240V single-phase power, it delivers up to 315A at a 60% duty cycle, bringing substantial welding capacity to shops without three-phase service. From daily fabrication to demanding repair work, the Tempest 412i is built to earn its place in your shop.
This MIG package includes everything to make it a true shop go-to welder, with both cart and external Vortex 205 Wire feeder.
- Operating on 240V 1 Phase yields up to 315A output at 60% Duty Cycle
- Operating on 480V 3 Phase power yields up to 400A output at 60% Duty Cycle
- True DC Power Source for MIG, DC TIG, Stick and gouging operations
- Simple, intuitive controls for easy setup and adjustment
- Bright, easy-to-read LCD for reading the screen at a distance
- Detachable wire feeder allows wire feeder to be carried without moving the powersource
- Optional longer Umbilicals for greater service distances with MIG
- Push-Pull Gun and Spool Gun Capable for additional Aluminum wire feeding choices
- Optional Wire Feeders/SuitCase feeders available
22 gauge to 1/2+"
20 gauge to 1/2+"
1/8"- 1/2+"
Common Recommended Metal Types and capabilities For DC TIG**:
.015" to 1/2"
.015" to 1/2"
Not to be welded with DC TIG.
Gouging:
up to 1/4" electrode (@ 400A on 480V)
480V 3 Phase 50/60Hz
| Max Inrush Amps (I1Max) | 240V 1 Phase 50/60Hz: 58.4 A
480V 3 Phase 50/60Hz: 22.8 A
| Rated Effective Amps (I1Eff) | 240V 1 Phase 50/60Hz: 46 A
480V 3 Phase 50/60Hz: 18 A
| LCD Screen | No
| Memory | No
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/29.8V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/26.5V Rated Output
| MIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/34V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 315A/29.8V Rated Output
| MIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz MIG Amp DC Output Range: 30 to 400 Amps
| Pre-Flow Time | Auto ON or OFF Seconds
| Post-Flow Time | Auto ON or OFF Seconds
| MIG Pulse | None
| Adjustable Factory Pulse Presets | No
| Spool Sizes | 12”
| Stock Drive Roll Wire Sizes Installed | .045” (.047 or 3/64”)
.062”
(External Feeder)
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
| Wire Feed Speed | 825 IPM
| Torch/Gun | North 36 Series 10 Ft.
| Important MIG Specification Notes | Actual MIG gun type and configuration ultimately depends upon the wire feeder type and the optional accessories purchased. Torch or Gun may vary depending upon feeder or suitcase configuration. Multiple gun options exist for each feeder type if a feeder is purchased separately
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/22.6V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/28V Rated Output
| TIG Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 400A/26V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 315A/22.6V Rated Output
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp DC Output Range: 5 to 315 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 22.6 Volts
| TIG Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz TIG Amp DC Output Range: 5 to 400 Amps
480V 3 Phase 50/60Hz TIG Volt DC Output Range: 10.2 to 26 Volts
Lift Start With Remote
| Pre-Flow Time | Auto/Off Seconds
| Post-Flow Time | Auto/Off Seconds
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 250A/30V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 200A/28V Rated Output
| Stick Duty Cycle 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 315A/32.6V Rated Output
480V 3 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 250A/30V Rated Output
| Stick Output Range 480V 3 Phase 50/60Hz | 480V 3 Phase 50/60Hz Stick Amp DC Output Range: 10 to 315 Amps
480V 3 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 32.6 Volts
| Hot Start Time | Fixed
| Arc Force | Adjustable
| Anti-Stick Protection | No
| Functions with Remote | Yes
| Carbon Arc Capable | Yes
| Maximum Carbon Arc Diameter | 1/4"
| TIG Function | Built In Gas Valve Standard Torch
| Important Stick Specification Notes | Unit has built in solenoid for TIG operation and supports foot pedal. Use TIG function for lift arc TIG, or TIG rig for scratch start in Stick. Lower arc force to 0 for TIG if using for scratch start in stick mode. Gouge function is a separate function. Use Gouge setting to gouge.
24 gauge to 1/2"
20 gauge to 1/2"
1/8"- 7/16"
.015" to 1/2+"
.015" to 1/2+"
**Capability varies based on skill, weldment size and general welding knowledge. The maximum limit is a practical recommended single pass limit based on the industry standard of performing thicker welds with multiple passes. Input voltage affects maximum output and capability as well.
- Rail Car Industry
- Pipe and Structural
- 36 Series MIG Gun 3m 10 ft.
- Drive Roll V-Groove Double (Steel/Stainless) – .045"-.062" (1.2-1.6mm)
- Vortex 205 MIG Wire Feeder Single Spool
- PowerCart 301 HD Welding Cart with Single Cylinder Capacity
- 6.5 Ft. Power Input Cable (Due to multi-phase/voltage configuration the power plug is not included)
- <400A Work Clamp 10 Ft. Cable and DINSE 35 Connector
