Hurricane 220 MTS-C, view 1
Hurricane 220 MTS-C, view 2
Hurricane 220 MTS-C, view 3
Hurricane 220 MTS-C, view 4
Hurricane 220 MTS-C, view 5
Hurricane 220 MTS-C, view 6
Hurricane 220 MTS-C, view 7
Hurricane 220 MTS-C, view 8
SKU# EV-HRCN-220
MIG
$2,999.00
$2,449.00
Save - $550.00
MIG
SKU# EV-HRCN-220
  • Unit Weight: 99 lb
  • Shipping Weight: 126 lb
The Hurricane 220 MTS-C is a professional true all-in-one welder and plasma cutter. It combines MIG, AC/DC TIG, DC Stick welding, and Plasma cutting into one compact, portable unit with a heavy duty 4 roller wire drive system. Switch processes quickly with a simple torch change after selecting your process. This gives you the versatility to tackle repairs and perform light fabrication in a cut-and-weld format without swapping multiple machines. On the rear of the unit, there are three, separate gas inlets, one each for MIG, TIG and Plasma Cutting.
With up to 225A of MIG and TIG output, it welds material up to 5/16" in a single pass and thicker sections up to 3/8"–1/2" with multiple passes. The integrated 40A plasma cutter delivers clean cuts up to 1/2" thick, with additional severance capacity. This is more than enough cutting power to keep up with the welding ability of the welder.
Its compact inverter design fits easily into most service bodies and allows one-person loading and transport. An 8" wire spool capacity accommodates approximately 10–12 lbs. of wire, while a 35% duty cycle at maximum output supports everyday shop and field work.
To finish off the MIG operation capability, the Hurricane 220 MTS-C also supports both optional spool-gun and push-pull guns offered by Everlast.
  1. MIG, AC/DC Pulse TIG, DC Stick Welder with Plasma cutting function
  2. 4 Roller drive system for smoothly feeding wire
  3. Use 8" or 4" spools of wire (10-12 lb. or 2 lb spools)
  4. Dual Voltage Input for jobsite portability
  5. Low air requirements at only 5.3 cfm for plasma cutting
  6. Run-in feature for MIG for easier starting of arc
  7. Spool Gun and Push-Pull Gun operation supported (Guns are optional)
  8. Water-Cooler power supply on rear for use with optional water-cooler.
  2. 8,500 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28 A
240V 1 Phase 50/60Hz: 31 A
120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 16 A
5.1 inches
Type
TFT
Resolution
HD 720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 225A/25.3V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 225 Amps
88V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-5 Seconds
0-20 Seconds
0-1 Seconds
0-1 Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.035”
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Wire Feed Speed
120V: 400 IPM 240V: 600 IPM
Torch/Gun
24 Series 10 Ft.
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 5/16"
.015" to 5/16"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
  1. Up to 3/8" daily use
  2. Up to 1/2" clean cut
  3. Up to 5/8" severance cut
  4. Pierce up to 3/8"
  1. NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
Downloads
