Hurricane 220 MTS-C Spool Gun and Cart Package
SKU# EV-HRCN-220-BUNDLE
- Unit Weight: 99 lb
- Shipping Weight: 126 lb
The Hurricane 220 MTS-C Spool Gun and Cart bundle package includes everything that comes with the stock Hurricane 220-MTS including the accessory package, but it also includes the Parker DSP 240 Spool Gun and the NOVA PowerCart 375LF. This package is ideal for getting everything you need to get started welding (except for gas, wire and tungsten).
Includes:
- Hurricane 220 MTS-C
- Hurricane 220 MTS-C Accessory Package
- Parker DSP 240 Spool Gun
- NOVA PowerCart 375LF
- 8,500 Surge Watts
- Use for hand cutting plasma only. CNC use voids warranty.
240V 1 Phase 50/60Hz: 31 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 16 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/20.3V Rated Output
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 225A/25.3V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 225 Amps
| Open Circuit Voltage (OCV) | 88V
| Pre-Flow Time | 0-5 Seconds
| Post-Flow Time | 0-20 Seconds
| Up-Slope Time | 0-1 Seconds
| MIG Pulse | None
| Spool Sizes | 4”
8”
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Wire Feed Speed | 120V: 400 IPM 240V: 600 IPM
| Torch/Gun | 24 Series 10 Ft.
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/14.8V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 225A/19V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 225 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 225 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 15.5 to 25.3 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 225 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 25.3 Volts
Lift Start With Remote
| Start Amp Range AC | 20-125/225A
| Start Amp Range DC | 10-125/225A
| End Amp Range AC | 20-125/225A
| End Amp Range DC | 10-125/225A
| Up-Slope Time | 0-5 Seconds
| Down-Slope Time | 0-5 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Soft Square
Triangular
| AC Advanced Pulse Frequency | 0-10 Hz
| AC Frequency | 20-200 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 180A/27.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 140A/25.6V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 180 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 27.2 to 25.6 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| Plasma Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 25 Amps
120V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 90 Volts
| Plasma Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 40 Amps
240V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 96 Volts
| Open Circuit Voltage (OCV) | 300V
Non-HF
| Torch Type | iPT-40
| CNC Capable/Ready | No
| Gouging Capable | No
| Gouging Duties | No Gouging Permitted, Voids warranty
| Recommended Flow Rate (Air) | 4.5-5.3 CFM
| Compressor Built In | No
| Recommended Cutting Pressure Range | 65-75 PSI
| Remote | 2T
| Tip Saver Function | No
| Location of CNC Port | No CNC Port
| Torch Connector Type | Threaded with DINSE adapter
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 5/16"
.015" to 5/16"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
- Up to 3/8" daily use
- Up to 1/2" clean cut
- Up to 5/8" severance cut
- Pierce up to 3/8"
- NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
- 24 Series MIG Gun 3m 10 ft.
- iPT-40 Hand Plasma Torch Blow Back Start 14 Ft. DINSE 35 Style Connector
- Parker DSP 240A Spool Gun (7 Pin) 25 Ft. Euro Quick Connect
- 240 to 120V Pigtail Power Plug Adapter
- Starter Plasma Consumable Kit ( 35-40Amp consumable size)
- Starter TIG Consumable Kit
