Hurricane 220 MTS-C & Cart 375LF & Nova Kit (Bundle)
SKU# EV-HRCN-220-BUNDLE-2
- Unit Weight: 99 lb
- Shipping Weight: 126 lb
The Hurricane 220 MTS-C is a professional true all-in-one welder and plasma cutter. It combines MIG, AC/DC TIG, DC Stick welding, and Plasma cutting into one compact, portable unit with a heavy duty 4 roller wire drive system. Switch processes quickly with a simple torch change after selecting your process. This gives you the versatility to tackle repairs and perform light fabrication in a cut-and-weld format without swapping multiple machines. On the rear of the unit, there are three, separate gas inlets, one each for MIG, TIG and Plasma Cutting.
With up to 225A of MIG and TIG output, it welds material up to 5/16" in a single pass and thicker sections up to 3/8"–1/2" with multiple passes. The integrated 40A plasma cutter delivers clean cuts up to 1/2" thick, with additional severance capacity. This is more than enough cutting power to keep up with the welding ability of the welder.
Its compact inverter design fits easily into most service bodies and allows one-person loading and transport. An 8" wire spool capacity accommodates approximately 10–12 lbs. of wire, while a 35% duty cycle at maximum output supports everyday shop and field work.
To finish off the MIG operation capability, the Hurricane 220 MTS-C also supports both optional spool-gun and push-pull guns offered by Everlast.
- MIG, AC/DC Pulse TIG, DC Stick Welder with Plasma cutting function
- 4 Roller drive system for smoothly feeding wire
- Use 8" or 4" spools of wire (10-12 lb. or 2 lb spools)
- Dual Voltage Input for jobsite portability
- Low air requirements at only 5.3 cfm for plasma cutting
- Run-in feature for MIG for easier starting of arc
- Spool Gun and Push-Pull Gun operation supported (Guns are optional)
- Water-Cooler power supply on rear for use with optional water-cooler.
- 8500 Surge Watts
- Use for hand cutting plasma only. CNC use voids warranty.
240V 1 Phase 50/60Hz: 31 A
| Rated Effective Amps (I1Eff) | 120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 16 A
| LCD Screen | 5.1 inches
| Type | TFT
| Resolution | HD 720
| Memory | 30 Programs
| MIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 125A/20.3V Rated Output
| MIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 225A/25.3V Rated Output
| MIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 125 Amps
| MIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 225 Amps
| Open Circuit Voltage (OCV) | 88V
| Pre-Flow Time | 0-5 Seconds
| Post-Flow Time | 0-20 Seconds
| Up-Slope Time | 0-1 Seconds
| MIG Pulse | None
| Spool Sizes | 4”
8”
| Water Cooler Capable | Yes
| Spool Gun Capable | Yes
| Push Pull Gun Capable | Yes
| MIG Functions | Wire Jog
Run-In
| Wire Feed Speed | 120V: 400 IPM 240V: 600 IPM
| Torch/Gun | 24 Series 10 Ft.
| TIG Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 125A/14.8V Rated Output
| TIG Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 225A/19V Rated Output
240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 200A/18V Rated Output
| TIG Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 125 Amps
120V 1 Phase 50/60Hz TIG Volt AC Output Range: 10.8 to 15 Volts
120V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 225 Amps
120V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 15 Volts
| TIG Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz TIG Amp AC Output Range: 20 to 225 Amps
240V 1 Phase 50/60Hz TIG Volt AC Output Range: 15.5 to 25.3 Volts
240V 1 Phase 50/60Hz TIG Amp DC Output Range: 10 to 225 Amps
240V 1 Phase 50/60Hz TIG Volt DC Output Range: 10.4 to 25.3 Volts
Lift Start With Remote
| Start Amp Range AC | 20-125/225A
| Start Amp Range DC | 10-125/225A
| End Amp Range AC | 20-125/225A
| End Amp Range DC | 10-125/225A
| Up-Slope Time | 0-5 Seconds
| Down-Slope Time | 0-5 Seconds
| TIG Pulse | AC
| AC Pulse Type | Standard
Soft Square
Triangular
| AC Advanced Pulse Frequency | 0-10 Hz
| AC Frequency | 20-200 Hz
| AC Wave Forms | Square
Soft Square
Triangular
| Stick Duty Cycle 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz: 35% Duty Cycle @ 40°C at 100A/24V Rated Output
120V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 80A/23.2V Rated Output
| Stick Duty Cycle 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz: 60% Duty Cycle @ 40°C at 180A/27.2V Rated Output
240V 1 Phase 50/60Hz: 100% Duty Cycle @ 40°C at 140A/25.6V Rated Output
| Stick Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 100 Amps
120V 1 Phase 50/60Hz Stick Volt DC Output Range: 20.4 to 24 Volts
| Stick Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Stick Amp DC Output Range: 10 to 180 Amps
240V 1 Phase 50/60Hz Stick Volt DC Output Range: 27.2 to 25.6 Volts
| Arc Force | Adjustable
| Anti-Stick Protection | Yes
| Functions with Remote | No
| Plasma Output Range 120V 1 Phase 50/60Hz | 120V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 25 Amps
120V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 90 Volts
| Plasma Output Range 240V 1 Phase 50/60Hz | 240V 1 Phase 50/60Hz Plasma Amp DC Output Range: 20 to 40 Amps
240V 1 Phase 50/60Hz Plasma Volt DC Output Range: 88 to 96 Volts
| Open Circuit Voltage (OCV) | 300V
Non-HF
| Torch Type | iPT-40
| CNC Capable/Ready | No
| Gouging Capable | No
| Gouging Duties | No Gouging Permitted, Voids warranty
| Recommended Flow Rate (Air) | 4.5-5.3 CFM
| Compressor Built In | No
| Recommended Cutting Pressure Range | 65-75 PSI
| Remote | 2T
| Tip Saver Function | No
| Location of CNC Port | No CNC Port
| Torch Connector Type | Euro-Central Type
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 5/16"
.015" to 5/16"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
- Up to 3/8" daily use
- Up to 1/2" clean cut
- Up to 5/8" severance cut
- Pierce up to 3/8"
- NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
- 24 Series MIG Gun 3m 10 ft.
- iPT-40 Hand Plasma Torch Blow Back Start 14 Ft. Central Connector
- 240 to 120V Pigtail Power Plug Adapter
- Starter Plasma Consumable Kit ( 35-40Amp consumable size)
- Starter TIG Consumable Kit
