Hurricane 220 MTS-C & Parker DSP 240 Spool Gun & Cart 375LF (Bundle), view 1
Hurricane 220 MTS-C & Parker DSP 240 Spool Gun & Cart 375LF (Bundle), view 2
Hurricane 220 MTS-C & Parker DSP 240 Spool Gun & Cart 375LF (Bundle), view 3
Hurricane 220 MTS-C & Parker DSP 240 Spool Gun & Cart 375LF (Bundle), view 4
Hurricane 220 MTS-C & Parker DSP 240 Spool Gun & Cart 375LF (Bundle), view 5
Hurricane 220 MTS-C & Parker DSP 240 Spool Gun & Cart 375LF (Bundle), view 6
Hurricane 220 MTS-C & Parker DSP 240 Spool Gun & Cart 375LF (Bundle), view 7
SKU# EV-HRCN-220-BUNDLE
MIG
$3,398.00
$2,839.00
Save - $559.00
MIG
  • Unit Weight: 99 lb
  • Shipping Weight: 126 lb
The Hurricane 220 MTS-C Spool Gun and Cart bundle package includes everything that comes with the stock Hurricane 220-MTS including the accessory package, but it also includes the Parker DSP 240 Spool Gun and the NOVA PowerCart 375LF. This package is ideal for getting everything you need to get started welding (except for gas, wire and tungsten).
Includes:
  1. Hurricane 220 MTS-C
  2. Hurricane 220 MTS-C Accessory Package
  3. Parker DSP 240 Spool Gun
  4. NOVA PowerCart 375LF
  2. 8,500 Surge Watts
120V 1 Phase 50/60Hz
120V 1 Phase 50/60Hz: 28 A
240V 1 Phase 50/60Hz: 31 A
120V 1 Phase 50/60Hz: 17 A
240V 1 Phase 50/60Hz: 16 A
5.1 inches
Type
TFT
Resolution
HD 720
30 Programs
Cooler Control
Runs Continuously
240V 1 Phase 50/60Hz: 25% Duty Cycle @ 40°C at 225A/25.3V Rated Output
240V 1 Phase 50/60Hz MIG Amp DC Output Range: 30 to 225 Amps
88V
Start Wire Feed Speed
Adjustable
End Wire Feed Speed
Adjustable
0-5 Seconds
0-20 Seconds
0-1 Seconds
0-1 Seconds
MIG Pulse
None
Spool Sizes
4”
8”
.035”
4
PowerSet Simplified Pro Setup
Water Cooler Capable
Spool Gun Capable
Push Pull Gun Capable
MIG Functions
Wire Jog
Run-In
Wire Feed Speed
120V: 400 IPM 240V: 600 IPM
Torch/Gun
24 Series 10 Ft.
24 gauge to 3/8"
20 gauge to 3/8"
1/8"- 5/16"
.015" to 5/16"
.015" to 5/16"
.025"- 1/4"
1/16"- 5/32"
  1. Up to 3/8" daily use
  2. Up to 1/2" clean cut
  3. Up to 5/8" severance cut
  4. Pierce up to 3/8"
  1. NOT RATED FOR CNC APPLICATIONS. DO NOT USE OR WARRANTY WILL BE VOIDED.
